10-20-2021, 06:55 PM
Fuel coming out of fill point
Filled camper today with fuel and when I removed the fill nozzle fuel came out. Did not think to much about it but the engine became hard to start. Pulled out the interstate and no power. Thought I had bad fuel and added a water remover to fuel. After many attempts to run down the road to clear what I thought was bad fuel I decided to add clean fuel. When i opened the fuel cap after a few seconds fuel came pouring out. Anyone have any idea the cause? It seems like the fuel tank is being pressurized somehow causing the engine not produce enough power
10-21-2021, 08:28 AM
I think I would start by replacing the fuel cap sounds like it is not venting as it should, this is a guess on my part but something I experienced on my old class A. Let the forum know what you find.
Retired Navy
2016 Flagstaff 26 FKWS
10-21-2021, 08:42 AM
Sounds like a clogged tank vent/purge. Maybe in the evaporative emission system?
2016 Salem 27RKSS
10-21-2021, 10:49 AM
Went to a repair shop and found i put gas in my diesel machine. Grabbed a green handle at a BP station thinking it was diesel but it was gas. Stupid mistake!!!
10-21-2021, 10:50 AM
Thanks for the reply, please repeat do not do my mistake!!!!
10-21-2021, 12:11 PM
This is more common than you know. There are several threads on this forum of accounts of folks making the same mistake. Colors on fuel dispensers are not standardized. The colors used are strictly the purview of the pump manufacturers such as Gilbarco and Tokeim. The marketing folks have duped the public into falsely relying on colors and pictograms rather then actually reading words. A few things are standard, though; Diesel will never have an octane reading, Diesel fuel will never come out of the Gasoline nozzle, and Gasoline will never come out of the Diesel nozzle.
2016 Salem 27RKSS
10-21-2021, 12:29 PM
After seeing many green pump handles on gasoline pumps I have become totally paranoid. I check everything about five times to ensure I have Diesel. I feel your pain.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
10-21-2021, 02:56 PM
2014 XLR 27HFS
... but that doesn't address gas pouring out after you fill it...
Dave & Audrey
10-21-2021, 07:04 PM
U are correct about the overflow. The repairs will be complete tomorrow and I will fill it, hope it doesn't overflow. Perhaps the vapor pressure of gas was to much for the diesel tank.
10-22-2021, 07:29 AM
The mechanic said the diesel tank has no vent unlike a gas tank so vapor pressure built up when running down the road so when I removed the vent cap out came the fuel.
10-22-2021, 07:33 AM
What was the “repair” they did? Any damage? I once put 10 gal of gas in my diesel, quickly switched to diesel. Lucky the fuel tank was almost empty 100 gal.
Good travels.
10-22-2021, 10:14 AM
There was damage-had to replace fuel pump, fuel filter, drain all fuel out. May have future problems with some sensors or fuel injectors so we will see.
10-22-2021, 10:16 AM
I put in 20 gallons in a 26 gallon tank so had to drain the tank
10-22-2021, 10:49 AM
Ive had a canadian friend reallize at about the 40 gallon mark.stopped then added transmission fluid ran it out ,changed filter refilled and all ok.sure that he got lucky.
10-22-2021, 06:47 PM
Got check engine light at 33 miles, back to shop. Both NOX sensors will be replaced tomorrow. Engine is running good, thank god!
10-27-2021, 08:40 AM
I would say green IS the diesel standard every where I go accept BP!
I stopped in BP once when running out gas on my KTM 690 motorcycle. I grabbed the non green handle (which ended up being diesel) but the smell alerted me after I pumped about a quart. So I filled the tank the rest of the way with gas (and it actually ran better) Now I always "sniff test" the nozzle before pumping. Same with filling my boat with non ethanol. the diesel pump is right next to the non ethanol so I sniff test to make sure the boat gets gas.
I have heard of so many people filling diesel trucks with gas at this BP near me, and everyone called HQ, so they know there is a problem, but they just don't care.
10-27-2021, 09:00 AM
Found out the damage is extensive. All fuel components are being replaced and all exhaust components. $24000 worth of repairs
10-27-2021, 09:32 AM
WOW! $24k?
I hope you trust the repair facility.
10-27-2021, 09:39 AM
Ouch - that hurts just thinking about it. 24K does seem rather expensive.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
10-27-2021, 10:00 AM
I did get lucky and found a really good place, Star Quality Auto Center in New Windsor NY. They have a guy who ran the shop at large mercedes dealer working on it.
