Old 09-28-2020, 12:02 PM   #1
Generator help
My well maintained generator is giving me a "generator alert" screen. It starts just fine but then shuts down. Any suggestions would be appreciated!
2015 Solera 24R
2014 Mercedes Chassis
Karter is offline   Reply With Quote
Old 09-28-2020, 12:28 PM   #2
I don't have any suggestions on the technical side of this, but, to clarify, do you have an Cummins/Onan propane generator? Probably model # 3.6KYFA26120? Maybe described as "RV QG3600 LP 3000 Watt LP Generator"?
2015 Solera 24R
DaveJordan is offline   Reply With Quote
Old 09-28-2020, 12:31 PM   #3
It's a diesel generator.
2015 Solera 24R
Old 09-28-2020, 12:35 PM   #4
Aha! Pretty different beast. Thanks for clarifying. Model info might be helpful if you can track it down - but they're all probably fairly similar.
2015 Solera 24R
Old 10-02-2020, 03:52 PM   #5
chroniekon's Avatar
I would check the oil level first. I don't know how your fuel supply line is plumbed, but some are plumbed in such a way that the generator will not drain your fuel tank. If your fuel tank is getting low, I would think that could be a problem.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
generator
