Originally Posted by tomkatb
Now and then there will be liquid in the drain lines when removing the cap. I stick the bucket that I use to store the drain elbow and gloves in to catch the dripping. I always double check that the valves are closed.
I have the valve to put in place of the cap when we might anticipate having to balance the gray tanks when no sewer is available. Makes the Blue boy waste tank easy to handle.
I just connect one end of the hose to the tote and hold the other end, open end facing up, under the end of the valve as I remove the cap. If there's anything there, it's an ounce or less, but I'm prepared.
You can do the same thing at the dump station--set up the far end first, then hold the near end under the valve assembly as you remove the cap. Then just rotate it up and connect it.
