The slide is 12v powered. Shore 110v converts to 12v through the converter ,, which drives the slide motor when plugged in through the 110v side. The bats charge from either the alternator (driving home charged the batteries enough), or from the converter when plugged in. You may have had low battery voltage. Slide went in when you were on shore power. You may have lost the 12v side. (breaker) Check that. Just sayin'
