Old 10-19-2020, 04:47 PM   #1
Sprinter Rear Compartment Door Prop Ideas
Looking for Ideas!! We have a rear slide on our 2015 Solera 24r with a large storage compartment door directly underneath. Because of its location, this door has no catch or latch to assist in keeping it open while using. It swings upward and is directly under the slide when open, and under the window when closed. Has anyone come up with any ideas as to how to prop or hold this fairly large door up just long enough to access needed items inside? We have considered trying to install a gas strut or possibly a latch of some sort that connects to the bottom of the slide, but worry it might damage the rubber gasket as it travels in/out. I just know someone has come up with a solution and hope you will share!! Thanks!
Cendyj is offline   Reply With Quote
Old 10-19-2020, 05:38 PM   #2
AudiDudi's Avatar
I put a spring latch above the compartment (like the one on the passenger side dorr that opens upwards). I put it on with double backed tape for those times when someone forgets the door is up and latched and puts out the rear slide.
I did the same thing for the generator compartment which makes dumping the tanks much easier.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 10-19-2020, 08:13 PM   #3
Thanks for the reply! That would definitely work when the slide is in, any ideas for when the slide is actually open?
Old 10-19-2020, 09:00 PM   #4
I purchased a strut kit for the rear hatch on my 24r from Hatchlift.com. The hatch holds horizontally so that I can access storage when the slide is out. Easy install - drill and screwdriver.
normtre is offline   Reply With Quote
Old 10-19-2020, 09:15 PM   #5
AudiDudi's Avatar
I try to make sure I have everything out before I put the slide out. Mostly chairs are needed and dolly straps put away. I try to avoid crawling under the slide to get stuff out.
Mike and JoAnne
Old 10-20-2020, 11:57 AM   #6
Mikegjax's Avatar
I use my head. It's not good for much else.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 10-20-2020, 12:03 PM   #7
Kanadian Kamper
kenandterry's Avatar
The only sure fire solution for if the slide is in or out........
Struts or your head. Your choice. Price will decide I guess.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 10-20-2020, 12:38 PM   #8
Hiking stick
I use an extended hiking stick to prop it up.
Tinbagel is offline   Reply With Quote
Old 10-20-2020, 01:16 PM   #9
I use our adjustable pole squeegee/scrubber against the inside lock mechanism. We carry it for windshield washing so it's always there. Very low tech!
Karter is offline   Reply With Quote
Old 10-20-2020, 01:30 PM   #10
Thanks for the ideas, folks! Tried the squeegee and the head, which usually wins on a pinch. We are looking into the struts as a permanent solution!
Old 10-20-2020, 03:22 PM   #11
TomAR's Avatar
Hatchlift, like this. One for each side:
2018 Sunseeker 2400R MBS (w/dinette)
TomAR is offline   Reply With Quote
Old 10-20-2020, 04:18 PM   #12
I put two of these on (black). One wasn't enough to hold the door open; two works great.
https://www.amazon.com/MOTORHOME-ROU...3228625&sr=8-6
2015 Forest River Solera 24R
2009 Honda CRV Toad
lacamastraveler is offline   Reply With Quote
Old 10-20-2020, 04:19 PM   #13
I forgot to mention. I bought stickon types because I didn't want drill holes
2009 Honda CRV Toad
Old 10-20-2020, 04:34 PM   #14
AudiDudi's Avatar
I also didn't want to drill holes and I used doubled sided tape. I only needed to install 1. I'd be afraid if they were screwed in and the slide was opened, you'd make a mess. I did the same thing for the side generator/dump valve compartment.
Mike and JoAnne
Old 10-20-2020, 04:41 PM   #15
TomAR's Avatar
The problem is not opening the sllde with the hatch open. However, CLOSING the slide could be a real issue. Never open the hatch and leave it open!!!
Old 10-20-2020, 04:41 PM   #16
TowPro's Avatar
I was thinking about this very problem today. Looking around the campground we are in I noticed some the hatchs are installed with the hinge is on the bottom so the door folds down.
2019 Forest River Forester MBS 2401R
TowPro is offline   Reply With Quote
Old 10-20-2020, 05:31 PM   #17
Thanks, Tom! That looks like it would do the trick. Do you happen to remember the size that you ordered, as I see on the website that hatch lift has many options.
Old 10-20-2020, 07:34 PM   #18
TomAR's Avatar
I went directly to
https://www.hatchlift.com/hatchlift-kit
although they are also available on Amazon.
From the size chart, I picked 'Small", HLK-SM, and needed two kits. About $100 total.
I put a small wood block on the 'far' side of the lower mount, to help reinforce the compartment flange.
The trickiest part is figuring out exactly where to mount, on door and on frame. I'll take some measurements and PM you later in the week, ok?
Old 10-20-2020, 07:41 PM   #19
Perfect!
Old 10-24-2020, 05:51 AM   #20
TomAR's Avatar
Hatchlift on rear compartment door FR Sunseeker 2400R
See pics
Name:	both pistons installed.jpg
ID:	241786   Click image for larger version
Name:	distance from top edge to centerline of piston connection-10.75inches .jpg
ID:	241787   Click image for larger version
Name:	plate location on door.jpg
ID:	241788   Click image for larger version
Name:	plate location on door-2.jpg
ID:	241789   Click image for larger version
Name:	wooden backer block.jpg
door
