We're still hunkered down in central Oregon but couldn't resist a trip to our daughter's ranch 30 minutes away to help with chores.
When I got ready to leave I fully raised the rear stabilizers on my 2017 2401WS MBS but when I started the engine, the warning tone for extended stabilizers sounded.
I extended and retracted several times to no avail. Rather than listen to the high pitched tone all the way home I forced the circuit breaker to pop by raising both stabilizers simultaneously and keeping the rocker switches depressed for a few seconds after they were fully retracted.
Does anyone have experience with a similar problem? Would the sensor be a part directly attached to one or both of the stabilizers, perhaps?
After forcing the circuit breaker to pop and returning home I reset the breaker, lowered the stabilizers, checked for an alarm and it worked. I raised the stabilizers, restarted the engine, and no alarm. Has worked as advertised since.
On my 2017 2401WS there is a black panel secured with two thumb screws in the stepwell on the left as you enter the coach.
I located it when my jacks first failed. There is a warning posted regarding electrical hazards of opening the panel and recommends disconnecting the battery and/or shore power before opening. I didn't as I simply wanted to see what was behind it.
There is a vertical row of mini circuit breakers. One was popped so I reset it and all was well.
If I try to lower both jacks at the same time, or if I lower one and the switch doesn't return to the neutral position on its own before lowering the other, the breaker pops every time.
We have a 2020 Sunseeker on the Mercedes chassis. Driving home from a recent trip the stabilizer alarm started up. I pulled over and checked the stabilizers and both were uptight and snug. Covered the alarm with tape to stop the noise. Any ideas on how to fix this bug?
As described in my first post, Iwas able to force the breaker to open by holding both rocker switches in the up position after the jacks were retracted. After resetting the breaker the alarm stopped sounding.
The problem recurs from time to time tho. I found that by retracting the jacks and then cycling the driver side jack down and up an inch or so, the alarm would clear. Sometimes simply punching the retract side of rocker switch a few times works too.
