Jacks
On my 2401WS there is a panel on the left wall of the first step entering the coach. The panel cover is secured with two thumbscrews and there is an electrical hazard warning on it.
When my jacks failed to retract and I couldn't find another breaker or fuse I opened that panel and found a vertical row of very small circuit breakers, of a design I'd never seen before.
One small white tab on one of the breakers was sticking out further than the others. When I pushed it in the jacks started working.
I have found that if I try to lower both jacks at the same time or when lowering one at a time I fail to ensure that an individual switch did not return to the neutral position before lowering the second jack, the breaker pops every time.
oreddie
'17 Forester 2401WS
