It sounds like a low fluid issue in the system. MOST, but not ALL, stabilizer jack systems on the MB/Forest River platform use automatic transmission fluid as the hydraulic medium. Yes, fluid will leak out or, even more likely, the system may not have been fully filled at the factory due to air being in the lines.
Since the jacks have now been operated, thereby purging the air from the lines, you can now visually check the fluid level in the plastic reservoir tank by getting underneath your rig. Review the manual supplied with your RV or google the manual for your product. You will probably have to remove a small metal protective cover over the reservoir to service the unit, but it is no big deal.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
