Old 06-13-2021, 07:17 AM   #1
River.Rat's Avatar
TV Coax
Just recently purchased a 2016 2401W.
In the cabinet above the door, left sidewall where the TV plugs in, behind the power/amplifier plate is another plate with 3 coax connectors, there is a coax cable between the top and bottom connectors.
What are the 3 connectors and why the strap between top and bottom?
Thanks...
River.Rat is offline   Reply With Quote
Old 06-13-2021, 07:42 AM   #2
Retired Army MSG!
lazyjj's Avatar
Quite possible these are connectors for cable or satellite.
lazyjj is offline   Reply With Quote
Old 06-13-2021, 11:48 AM   #3
AudiDudi's Avatar
Do you have 2 TVs? It may be connecting the bedroom to the living area.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 06-13-2021, 12:21 PM   #4
U.S.ArmyVeteran's Avatar
Question? Do all the TVs work as you expected? Cable and Off the Air?
If so and your just curious. I get that.
Turn on all your TVs and disconnect one of the cables. You will probably get a clue as to where one end goes. Process of elimination.
Good Luck.
U.S.ArmyVeteran is offline   Reply With Quote
Old 06-13-2021, 03:15 PM   #5
See response #27 on this thread:
https://www.forestriverforums.com/fo...tml#post792466
It's from Brian Clemens (still the best!) and explains that the center connector is pre-wired for a rooftop satellite dish. I think this arrangement allows you to insert a satellite receiver into the mix, connecting one of the other two coax's to a cable or antenna in on the receiver, connecting the center connector to the satellite in, and connecting the third connector to a TV out on the receiver.
I think.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 06-13-2021, 04:19 PM   #6
River.Rat's Avatar
Thank you all for your replies, have a better idea of what I've got. I'll have to do some more experimenting to determine where all these cables go.
2016 Forester MBS 2401W
2015 Chevy Equinox
