Old 10-24-2020, 06:54 AM   #1
TV Help please
I have a 2018 Forester 2401W. I canít seem to figure out how to use/access the cable TV provided by campground.
My coax cable is new. I have one end plugged into site and the other end plugged into the outside cable port on RV. I then have went into the menus on TV and switched to cable and scanned for channels. I get zero results. Iíve completed this process at three other campgrounds with same results.
I do get signal from roof top HD antenna. And depending on my location it works fine.
What am I missing?
Thanks,
John
jwb747 is offline   Reply With Quote
Old 10-24-2020, 07:03 AM   #2
SeaDog's Avatar
Make sure that you are turning off the over the air antenna booster. You may have to search out the connections/splitter to ensure it connected.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-24-2020, 11:09 AM   #3
In my 2016 24R I have a small button next to a plug in overhead storage that I have to push in to allow TV to work.
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 10-24-2020, 11:14 AM   #4
I have two tv's the one in the living room is hooked up to the cable system, the one in the bedroom is not. Don't know how many tv's you have
Kimber45 is offline   Reply With Quote
Old 10-24-2020, 10:46 PM   #5
Big thanks. It was simply the button.
Old 10-24-2020, 11:38 PM   #6
bikendan's Avatar
This is usually the solution. That's why so many members post this fix.
