Old 02-14-2021, 12:50 PM   #1
Water leak.
2018 Sunseeker MBS 2400/W.
Water leak from inside range hood. I removed the wiring cover (to switches) and the water was running down the wiring then dripping onto the stove top. Before I start removing stuff to find the source I thought I’d check the experience crowd to see if anyone has dealt with this before! Thanks!
Automatic_11 is offline   Reply With Quote
Old 02-14-2021, 10:02 PM   #2
Mikegjax's Avatar
Could be many things. If your frig is next to the range hood, check the cover over frig roof vent. Water can run from far away places that you would not expect.
I built a blower set up that I use to pressurize the RV. I then use a spray bottle with soap and water to spray the roof and look for bubbles.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 02-15-2021, 03:41 PM   #3
Commercial Member
ES_FR's Avatar
Automatic_11,
We would be happy to assist you with your 2018 Sunseeker MBS. Because your ongoing satisfaction is very important to us, we invite you to contact Kary Katzenberger in our Customer service department through the following personalized and direct link: https://www.forestriverinc.com/Direc...90004274831599.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 05-11-2021, 04:18 PM   #4
I had the same problem. I found that a plastic cover is set on the joint at roof and wall. I removed that plastic to find a hole in the aluminum gutter like someone had miss to install a screw. Then i resolved an other problem that moulding goes at the front seal with some silicone at front canopy they had put sealer over it but not under it so it was a good entrance for water when i drove on highway my wife received water on her knee solve with a drop of silicone.
Shickshack is offline   Reply With Quote
leak, water, water leak
