Old 08-03-2021, 06:20 AM   #1
Water leak
Have. 2015 2400ws with a spongy floor area right behind the drivers seat in the corner. Have yet to find source. Can a leaky storage seal in the slide out be the cause, as not sure how water could travel from the compartment to the floor since it is in the slide out metal box. Any suggestions would be appreciated. Still doing water tests with hoseÖ
fishheads is offline   Reply With Quote
Old 08-03-2021, 06:27 AM   #2
Mikegjax's Avatar
Water can flow from the top or side of the slide out to the floor. Next time it rains, check for wet area at the corners of the slide out .
2014 Solera 24R
USN Retired
Mikegjax is online now   Reply With Quote
Old 08-03-2021, 09:35 AM   #3
Thanks Mike.
This morning using a garden hose, found water entering from top front slide out seal. Wonder if a full seal replacement is warranted on top and sides, since 6 years old, and the cost?
Old 08-03-2021, 08:34 PM   #4
Mikegjax's Avatar
If the seals are not dry and brittle or cracking, I would think that they don't need replacing. One thing that I do is place blocking (not much) to tilt the Rv so water runs away from the slide opening.
I do treat my seals with spray silicone when I wash and wax.
2014 Solera 24R
USN Retired
leak, water, water leak
