Old 02-01-2016, 06:35 PM   #21
Of course, the problem is most circuits don't support a "one way path" unless they use a relay...and, as I posited, if you leave the key on the path will continue to be hot and the relay will stay energized. If you then hit your house batteries with 13.5 to 14 volts, some of the current will end up in your TV battery. Not the best and an easy way to kill you TV battery with house loads.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 11-02-2018, 09:15 PM   #22
Thank you all!!!
After losing power last night on the road due to watching TV, running the water pump and the lights, I called AAA roadside to jump the generator (which they don't do BTW).
Upon waking in the morning this thread go me back in the good graces with the Mrs, thanks so much!
2016 MBS Forester 2401R
baranski is offline   Reply With Quote
battery, generator
