[QUOTE=bobandpatsyrvers;2525187]Before you sign, check out the closet spaces to see if you can accept the limited space. The drawers in the master bedroom are great but will be a questionable trade off for a "regular" size closet. I bought an 8336bh because of the washer/dryer hookup. The hookup is in the closet in the master bedroom. The closet space looks good until you realize the washer/dryer will take up two thirds of the closet space. That will leave you with one closet about three feet wide by 55 inches tall. The washer/dryer has to be an all in one because the closet space will not allow for a stack-able unit. If you aren't going to use a washer/dryer the closet space should be adequate.
The closet space in the bathroom will consist of three small pie shaped nooks and a medicine cabinet. The medicine cabinet is the largest storage unit in the room.
The cabinet space in the kitchen/living area is great.
The bunk area is a nice set up but I'm thinking about somehow converting one of the upper bunks into a storage area to make up for the lack of closet space.
An edit I must add is that there are no driver side windows, so you will be blinded on the driver side and will not be able to see the world from that point of view.
Think carefully before you purchase.
