Replaced the board beneath the mattress due to mold.
Replaced the brackets that hold the side skirts. 3 were installed from the factory, none actually attached.
Replaced the blown converter fuses day 2. Not charging.
Repaired the wiring short at the circuit breaker, probably what blew the converter fuses.
Disassemble and cleaned the metal shavings out of the dead bolt, so I could lock the door.
Glued the slide seal in placeafter it slid out driving home from the desert.
Still need to address the side skirts pulling away from the body.
Still need to address the sticking screen door.
