Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Thread Tools Search this Thread Display Modes
The wheeled hovel
johnbryanpeters johnbryanpeters is offline
Registry
RV Name The wheeled hovel
Year 2013
Make R-Pod
Model RP-171
Length 18' 4"
2013 R-Pod RP-171
Basic Info Bought used in July 2016, had been used two times.
Exterior
2013 R-Pod RP-171 Exterior
Fabricated battery power distribution panel with battery selector/cutoff switch, bus bars, and 100 A shunt for battery monitor to be added later.
Interior
Hinged cover to power distribution void space under driver side dinette cushion; installed baggage door catches, part number 20X32510A, to hold that cover open when in use. Added the same catch for storage compartments on both sides of dinette.
Same as above for space under driver side of bed that holds hot water heater and water pump.
Installed voltmeter over stereo and 12 V outlet and USB ports between kitchen and dinette.
Renovations and Repairs
Shower drain was leaking, tightened connection to P-trap.
2013, led, r-pod, wheel
Search this Thread:
Advanced Search
