02-14-2017, 09:30 PM
Hot water tank by pass kit and RV antifreeze hose from water pump
Just curious if anyone else's 2017 Vengeance 25V didn't come with a Hot water by pass kit and the clear hose from the water pump where you can stick it into the bottle to winterize the RV?
My Hot Water tank only have two valves, one for hot and one for cold. No valve in the middle to by pass the tank. There is no clear hose that is extra to stick in a bottle of RV anti freeze to winterize next year. Our RV came from Northern Minn and there is nothing in the water lines. They are blown out.
T and N Barrett
2017 Forest River Vengeance 25V
2016 Chevy 2500 HD 4x4
2009 Harley Davidson Ultra Classic
02-14-2017, 09:43 PM
WH bypass and winterizing kit are two different things. Some WH only have two valves to accomplish the WH bypass. The winterizing kit ( if installed) should be on the input side of the water pump. If winterizing kit is not installed, it is a very easy inexpensive installation.
Does your bypass look like this.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-14-2017, 10:06 PM
And if not exactly like the one Bob's pic, does it look like this one in this post?
http://www.forestriverforums.com/for...ml#post1341683
2011 Flagstaff 831 RLBSS
02-14-2017, 10:07 PM
There are only valves on mine. I need to look but there is not a center valve like on previous rv's I have owned. Only having two valves how does it by pass it?
T and N Barrett
02-14-2017, 10:08 PM
Is yours like the one in Bob's post or perhaps like the one in my link?
02-14-2017, 10:10 PM
I meant to say two valves on mine. But I think they are farther back from the middle line that runs up and down
T and N Barrett
02-14-2017, 10:11 PM
A pic would help your cause tremendously.
02-14-2017, 10:12 PM
I will take a pic tomorrow and post it. But they just look like shut off valves .
T and N Barrett
I agree. Sorry.
T and N Barrett
02-15-2017, 05:47 PM
hw bypass
The two valves are each 3 way valves. Other bypass setups have three shutoff valves.
02-16-2017, 08:20 PM
here is a picture of my hot water tank
Does this have a by pass kit even though it only has two valves? If so, how does it work. I am only familiar with the 3 valve system. there is a valve that is directly over the T section that connections the hot and cold water lines.
thanks
T and N Barrett
02-16-2017, 09:16 PM
It looks like the top valve is in the winterizing postion(pointing down no water going to the hot water heater)and the bottom valve also not letting any water into the HWH. I believe the valve handle points in the direction of the water flow.
02-16-2017, 10:19 PM
Thanks!
T and N Barrett
02-17-2017, 08:36 AM
thanks
Attachment 130059
It works pretty much the same way as in the link I posted above. The only difference is that the shutoff valve is on the cold water line of yours, instead of the hot water line in this one:
