Old 02-12-2024, 12:50 PM   #1
Is this NORMAL? 2 Black tanks, but??
Newbie to this forum and RV's. 2019 Forest River 324A13 Vengeance Rogue toy hauler with 1-1/2 bath and 2 Black tanks to drain.
QUESTION: if we're only using the front bathroom, does it share the same black tank drain somehow? Meaning, will (or can) the front black tank overflow into the rear tank?
We noticed a smell coming from the rear toilet and found it was backing up even though we do NOT use it! We emptied the rear black flush, but...
Physically we're not able to flush the front as often. Is this supposed to happen? Maybe the 2 lines are connected? Or is this a defect of some sort?
Very confused. Thank you!!
Randi is offline   Reply With Quote
Old 02-12-2024, 12:53 PM   #2
bikendan's Avatar
Moved thread from the General TT/5th Wheel Discussion section to the Toyhauler section's Vengeance sub-forum since the OP is asking for model-specific information and they own a Toyhauler.
Old 02-12-2024, 01:10 PM   #3
llr
I doubt if the 2 are connected but it is possible.
Do you use the sink in the half bath? This probably shares the black tank. My guess would be this is why it filled.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 02-12-2024, 02:33 PM   #4
rracer5's Avatar
X2
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-13-2024, 09:24 PM   #5
Hi,
No. We don't use that restroom at all due to it having problems. We actually thought we'd emptied it (turned water off and could see the bottom) after it backed up when... it's a long story...
But no. We do not use it at all. We started noticing a smell and realized it was coming from there. When we looked in that commode we saw "it" and cannot understand why.
Any thoughts would be greatly appreciated!
Thank you!
Old 02-13-2024, 09:29 PM   #6
Hi,
I'm not sure if my reply went to you or not but...
No. We don't use that restroom at all. After dumping and thinking it was (we turned the water off, flushed and saw the bottom) we've not used.
Noticed smell coming from there and saw "stuff" in liquid form.??
Crazy and we've no clue.
Thank you!!
Old 03-03-2024, 09:02 PM   #7
Originally Posted by rracer5 View Post
X2
Hi,
Is my message getting to anyone? ��������
Old 03-03-2024, 09:10 PM   #8
Mr. Dan's Avatar
Originally Posted by Randi View Post
Hi,
You have 4 visible posts plus 1 you deleted. Iím sorry if no one knows the answer to your queries.
Old 03-03-2024, 09:22 PM   #9
Retired Old Guy
IamProStreet's Avatar
I do not know your rig so this is just a wild guess, do you have 2 black tank flush fittings or just 1? If just 1 is your back black tank filling up when you are flushing the front one? You could empty both black tanks close both valves and turn on the flush for a bit then open the rear tank and see if it had filled up from the flush.
IamProStreet is offline   Reply With Quote
Old 03-03-2024, 09:23 PM   #10
How do I reply to the person asking a question? I thought it would have their name? I'm trying to reply to 2 diff ppl (you make another) but I'm just not seeing it.
Old 03-03-2024, 09:26 PM   #11
Thank you for replying. We have 2 black tanks we dump... but only 1 grey.
Old 03-03-2024, 09:33 PM   #12
Like this
Randi, just click the QUOTE button (not the Reply button) and the item you are referencing will appear in a cute little box, just like the one above.
Start your response on the line after the {/QUOTE} tag.
Larry
Larry-NC is offline   Reply With Quote
Old 03-04-2024, 01:11 AM   #13
Ok. I hit the quote and this looks much different
Old 03-04-2024, 08:40 AM   #14
Mookie58's Avatar
Hi Randi, welcome to the Forum. I suggest you contact Forest River technical support via their web-based contact form and ask for a simple drain line and holding tank diagram for your specific TT. Include year, model number, serial number in your request. This may help you determine if the tanks are connected and where the dump valves are. I made such a request to make sure only toilet water was going to the black tank in our Flagstaff TT and the tech staff at Forest River was quick to respond with the proper information, including a diagram. It's worth a shot for your TT.
2024 Flagstaff Micro Lite 21FBRS
2021 RAM 1500 Bighorn 5.7L Hemi
Take the high road. It's usually less muddy.
Mookie58 is offline   Reply With Quote
Old 03-04-2024, 09:00 AM   #15
Spend 20 minutes with some water and some food coloring and you can figure out which drain goes to which tank pretty easily.
After you empty the tanks, pour some colored water down one of your drains/toilet. Then check to see which tank it went into/comes out of.
Repeat with all drains. Done.
Iwritecode is online now   Reply With Quote
Old 03-12-2024, 09:58 AM   #16
Crawl under?
There's always crawling around underneath (sheets of cardboard help a lot on a gravel driveway) with a headlight or flashlight and seeing what's there. Along with just walking around the side of the RV or trailer and making sure there aren't any overlooked drain fittings or valves.
MrScott1 is offline   Reply With Quote
black, black tank, tank, tanks
