I'm not sure if this camper is junk or it's just smarter than me with no instructions! My leveling system is sounding an alarm. It's an automatic 6 point leveling system on a 2021 vengeance rogue. The screen says manually raise all jacks or hold retract to auto retract. All jacks are up. The front will lower to unhook the truck but it will not level. Any ideas?
I don’t have any ideas but Lippert’s customer service is actually quite helpful if you give them a call.
I would raise all Jack's and verify they are completely up. Then I would pull the fuse to the leveling system. Let it set a few minutes. Then install fuse again. Hopefully this will reset the unit. Hope it helps.
Just had LF and RM errors. Had to extend all the jacks manually to the ground and retract all jacks to up position and the beeping alarm finally stopped
