Old 06-03-2021, 05:36 PM   #1
Refrigerator
Ok just got our new Furrion fridge installed. Seems to be working fine but the light only works when the shore power or generator is on. Is this correct? Shouldn't the fridge and the light work off of 12vdc?
jeffnronda is offline   Reply With Quote
Old 06-03-2021, 11:21 PM   #2
Not if it is a Furrion AC only refrigerator. Then it would need an inverter to run off 12v DC.
However, if it is a DC refrigerator, is your battery disconnect switch turned on?
NavyLCDR is offline   Reply With Quote
Old 06-04-2021, 11:27 AM   #3
The dc is on and there’s an inverter. But it doesn’t seem to be working. Everything on this camper is a total mystery.
Old 06-04-2021, 11:30 AM   #4
bikendan's Avatar
Perhaps if you posted the fridge model number, we could identify what type of fridge it is.
Old 06-04-2021, 11:46 AM   #5
It's a mystery to us as well.
Forest River uses at least 12-15 different makes/models of refrigerators, maybe more. Not every R/V is equipped the same. Not even all Vengeance models are the same.
Some are 120v AC residential models, some are 12v only, some are a combination of 12v and LP gas.
Unless you give us additional information to work with, it will remain a mystery.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 06-04-2021, 02:42 PM   #6
ok it's a FCR14ACBQA-SS-01. It's a 120 vac fridge with a 12 vdc inverter. The inverter doesn't seem to be working. I climbed in the compartment and pushed the on/off button but nothing happened. There are no lights on the inverter at all. When I turn the shore power back on the green LED light on the inverter comes on. still nothing on the screen.
Old 06-10-2021, 09:17 AM   #7
Are your batteries charged? We have the same type fridge. We found that if the battery is week we can’t turn on the fridge at the inverter switch. I plugged a battery charger in and after about 30 min the fridge would come on. Just a thought.
philscobra is offline   Reply With Quote
Old 06-13-2021, 12:50 PM   #8
Another thing to look at is if your battery disconnect switch is off. It sounds like your inverter is not hooked to the batteries, when on shore power the inverter doesn't need to run but will have power to the button but when you remove shore power it has no power anywhere which makes me think your battery disconnect switch is turned off.
Keith_Schumaker is offline   Reply With Quote
refrigerator
