Originally Posted by nondem
If it comes to it, I'll swap to an F350 but it sure isn't easy to figure out what the capacities actually are looking at the Ford Spec sheets. The truck does have the 10k lbs GVWR option but depending on the model Vengeance I do see where that may be inadequate.
https://photos.app.goo.gl/9yqeHlN0d6gfTP5N2
Thoughts?
I have been reading your question and thought I would tell you I have a Chev 2500 HD Diesel crew with short box. I decided on the slide hitch when I updated my last hitch, and have found it to be an excellent choice. My last trailer was a 36 ft DRV which is a heavy trailer, and it worked well. I might add though, I did beef my rear suspension, adding an extra leaf spring and also those "axle bumpers" and the set up is great.
