04-12-2021, 10:27 PM
Water manifold
So we got a new camper with three water hook ups. I could not see myself constantly unhooking and hooking up a hose when I wanted to change inlets. So I made this. Manifold valve was from Amazon, rest was from hardware stores. I forgot to buy a plug for the left side but I did have a valve. Figured I could use it once in a while anyway.
04-13-2021, 07:25 AM
From past posts and videos I’ve seen I feel the check valve your using is wrong for this application and in the wrong position.
But I’m not a plumber.
Most people keep there black flush water supply completely separate, I understand at some point any configuration is connected which has confused me for years. People normally put a splitter at the source and use a different hose.
Very nice set up! But how do you take it off at the end of the week?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
04-13-2021, 09:10 AM
Someone will have to explain how the check valve is wrong. As installed it is closed until water pressure opens it. I am at a permanent spot so it stays hooked up for the season. To unhook it you just turn the black female knobs attached to the camper just as you would to unhook a hose.
Jim
04-13-2021, 11:34 AM
No Vacuum Break should check valve fail maybe????
04-13-2021, 03:29 PM
I understand things can and do fail. The check valve is in the closed position as mounted. I guess I don’t understand how it can fail, as positioned, as it will only open with water pressure below it. Or do only vacuum breaks never fail?
Jim
04-13-2021, 03:39 PM
I applaud your modification to your wetbay, Ive modified mine as well but differently, I keep the black tank flush completely separate.
However, in my case, I have yet to be able to use my Black Tank Flush and I have had now 3 Check Valves broke, damaged, never worked or arrived from Amazon DOA. So plenty of failures and I have not even used my system once!!!
You asked about how failures can happen, I came across this when doing my research.. Take it for what its worth.
https://www.thomasnet.com/insights/g...valve-failure/
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
04-13-2021, 04:13 PM
What is the 3rd connection? City water, black flush & ??
2020 Flagstaff Micro Lite 25BRDS SOLD!
2024 Brinkley Z3100
2021 Ford F-350 XLT 6.7L Power Stroke
04-13-2021, 06:51 PM
Freshwater tank fill, maybe?
04-13-2021, 07:54 PM
The check valve in line with the black tank is not needed and if the factory installed vacuum breaker/check valve is installed then another external check valve is not supposed to be utilized. The factory installed vacuum breaker/check valve will close the check valve side leading to the tank but the the valve body probably won't empty because residual pressure will not allow the water to exit the input line which is what the vacuum breaker is for. Of course this may not be a big deal since you are on a permanent spot it's just redundant.
04-13-2021, 10:48 PM
I understand your thinking, but answer me this. Do you use a different hose to connect the black tank flush? Do you use a different hose bib to attach your dedicated black tank hose to? Is that hose bib serviced from a different water source? You see my point? Fresh and black tank flush water comes from the same source, through the same bib, and can even go through the same hose. From what I can see there is a vacuum breaker inside my camper, but I wanted the extra assurance of an old fashioned, simple swing type, check valve. It is also gravity assisted because of the positioning.
Your link was informative, albeit basic.
Jim
Tank fill.
04-13-2021, 10:52 PM
As far as I can tell there is a vacuum breaker inside. The gate type of check valve should still work when the flow stops because of gravity acting on the swinging gate. I just added it for my peace of mind.
Jim
04-14-2021, 06:45 AM
As far as I can tell there is a vacuum breaker inside. The gate type of check valve should still work when the flow stops because of gravity acting on the swinging gate. Jim
If this is referencing the factory installed valve its check valve is a spring loaded ball bearing type check valve on the output side not gate type. There's to much ado about separate hoses and such for the black tank cleanout plumbing. You're fine. I'm done.
04-14-2021, 06:55 AM
Jim after some time on google I learned a few things. I always assumed gate type check valves had to be horizontal, I was wrong.
But on another note I’m still confused why people carry a separate hose for the black tank flush ? The hose is connected to the same source. It makes no sense to me and I was hoping to understand why people do it.
Again Nice job!
2014 Ram 3500 DRW
04-14-2021, 08:21 PM
Then there is this picture found on the internet........
Takes all kinds, I guess.
