<h3>The Power of Flo .</h3>Meet Flo .
Every RV owner knows flushing out your rig s water lines can be time consuming and expensive. But not anymore. With the Flo drain down system, you can clear your lines the moment you want to, at home or on the road.
Using compressed air pressure, Flo can drain your freshwater system in minutes leaving you with water that s ready for your family, friends, and pets to use. And it can help you prep your RV for winter, so you don t have to worry about frost damaging your water lines or tank.
FLOE 636 USES 12 VOLT SYSTEM AND BUILT IN AIR COMPRESSOR TO BLOW OUT/PURGE THE WATER OUT OF YOUR LINES. Plus, these systems work with more than just RVs.
Why Flo ?
Flushes stale, stagnant water out of pipes
Helps prevent frost damage during winter months
Saves time and money winterizing RV or boat with a professional
Drains water system in minutes
Easy installation, no dismantling necessary
View this ad at Forest River Classifieds -
FLOE 636 INDURATEC INTEGRATED WATER DRAIN DOWN SYSTEM
