Old 02-29-2020, 07:03 PM   #1
GE16 EXT 94026 10 Gallon Gas/Electric Atwood RV Hot Water Heater, New
Due to the weight this is a pickup only item in the Detroit area.
It is brand new never installed.
GE16 EXT 94026 10 Gallon Gas/Electric Atwood Hot Water HeaterBrand
New in the factory box, MSRP 949.99
The 94026 is lightweight and compact, with easily accessible controls for servicing. Fuel Saving Flexibility Atwood water heaters operate on LP gas. In addition, the GE16 EXT 94026 also operates from an electric source. With the electric option, the heater can be run either off an electrical hook up or a generator.Features:Also refered to as GE16EXT SP10 gallon capacityRecovery Gallons Per Hour: Gas: 13.5, Electric: 6.2, Combined: 19.7Corrosion resistant exterior8.5 GPH Recovery/Gas6.2 GPH Recovery/ElectricLight WeightEasily ServiceableAluminum Clad TankMatching Access DoorsMultiple protection features including high temp limit switch, thermostat amp; pressure/temp relief valvePre Installed winterizing bypass kit10 gallon models provide the equivalent of 16 gallons of hot waterExothermal Technology
View this ad at Forest River Classifieds - GE16 EXT 94026 10 Gallon Gas/Electric Atwood RV Hot Water He...
sundancer330 is offline   Reply With Quote
