If your rig is packing a 454, you want this drivetrain.
New, less than 2000 miles, GM crate HT502 cid 400 HP/540 Torque
500 lb/ft torque from 2500 4500 rpm. Try that with your 454.
8.75:1 compression means regular gas at any altitude
iron gen IV block and iron gen IV oval port heads accepts all stock manifolds. Currently fully dressed and driving with low rise stock dual plane and Quadrajet 4 barrel. Throw a Performer RPM and a ZZ cam on it and scare the old lady...
Full complement of 1984 accessories. Runs perfect.
New MSD HEI high output ignition system, the good stuff. No think, nothing to do here.
Electric fuel pump no mechanical
ProForm high torque gear reduction starter, stock couldn't hack it.
Doug Thorley Tri Y headers, silver ceramic coated, a work of art that makes the above numbers severely under rated. and full dual exhaust with Walker Super Turbo mufflers for 31 ft chassis. Wonderfully quiet, but they'll know you're packing heat when you stand on it to 5000 rpms.
Fresh Turbo 400, 1500 stall converter, shifts perfectly.
Gear Vendors Automatic .78 Overdrive. That's right, automatic overdrive 4th gear at 50 mph. With all this torque you don't need to spin the engine any more. Or have fun fooling around with the manual switch for gear splitting to get 6 speeds: first, first O/D, second, second O/D, third, final OD.
You'd be hard pressed to put this combo together for 15,000 June 2022 pricing .
I'll take half that OBO.
Located in Corvallis Oregon
View this ad at Forest River Classifieds -
Got Torque? GM 502/TH400/GV O/D complete drivetrain - Oregon
