Old 08-19-2022, 11:34 AM   #1
Large ZombieBox generator security and sound enclosure $995 - California
ZombieBox is a portable, weatherproof, noise reducing enclosure for portable and standby generators, compressors, industrial equipment, electronic, medical and laboratory equipment. Its unique universal design allows anyone with this type of equipment home owners, campers, tailgaters, contractors, food trucks, cabins, businesses and military or governments to reduce the decibel intensity of portable generators and other machinery without inhibiting airflow or the natural cooling properties.
Designed to be portable and self supporting, these innovative appliances can be assembled on location, without tools, in literally minutes! The ZombieBox can also be mounted to a rigid base for static and permanent backup generator applications. Built in ventilation and noise control systems manage heat build up and exhaust gases for complete noise reduction and total protection from the elements...including EMP's.
All materials and electrical components meet NFPA and ASTM certification requirements.
This ZombieBox is a little over a year old and works great! The only reason I m selling it is because I m buying an even bigger one for a larger generator.
This is for a Large Zombie Box measuring outside 44 L x 44 W x 45 H
This ZombieBox has the following upgrades and options added to it:
ArmorPlate a black rubberized industrial coating that reduces the noise by another 2 decibels
Z Pipe secondary exhaust heat control muffler provides an extra 15 exhaust noise reduction, between 2 4 dBA . The primary function of the Z Pipe system helps control temperatures and reduce the amount of maintenance required on the liners and fan.
Rubber 3/4 base mat These heavy duty base pads mats insulate the generator and box from transmitting noise to the surrounding area. It seals the bottom of the box eliminating any gaps where air and sound can escape or draw in debris and water.
5 Cable cord grommet For large cable ends, cord plugs, electrical conduit, or fuel lines.
Z Shield Weather guards Prevent rain, snow or debris from entering the box during operation or storage.
If you were to purchase this same sound enclosure new it would cost over 2,400 plus shipping AND take 2 months before being manufactured.
Obviously generator is NOT included.
View this ad at Forest River Classifieds - Large ZombieBox generator security and sound enclosure - Cal...
SacRV is offline   Reply With Quote
Old 08-30-2022, 12:34 PM   #2
Price reduced to $950.
2021 Cedar Creek Cottage 40CRS
Victron MultiPlus-II 12/3000/120-50 Solar installation
generator, california
