I purchased this pair of Yamaha EF2400iS inverter generators for use with my travel trailer. As it turned out, I always stayed at full hookup campsites and never used them on the road. These generators have served as backups at home during power failures and have been meticulously maintained,were started monthly, and the oil has been changed annually with full synthetic oil.
The first generator only has 131.2 hours, and the second generator has a total of 145.9 hours. The price of 900 includes both generators with hour meters, the parallel kit to join both generators together with a 30 AMP RV plug, 2 genuine Yamaha heavy duty covers, both owner's manuals, 12 volt DC battery charging cables, and 2 spark plug wrenches!
I would prefer to sell the pair of generators and accessories for 900 FIRM , but will separate them if necessary for 500 each FIRM . In the event that the generators are sold separately, the parallel kit will be available for 50. All sales must be in cash and picked up at my home in Macedonia, OH outside Cleveland .
Specifications for each generator from Yamaha:
Designed with the consumer in mind! Super quiet 53 58 dBA, it only weighs 70 pounds and produces 2400 watts of maximum power.Cleaner, quieter and more powerful, this generator is the next step forward in generator technology. TwinTech capability hook up two units for 4600 watts of maximum power. Auto decompression system reduces compression for easier starting. Gasoline petcock helps prevent carburetor contamination during storage. Easy access controls. Smart Throttle varies engine speed based on load improves fuel economy and reduces noise. Comfortable grip handles for easy portability and storage. OilWatch warning system and electrical overload breaker help prevent engine damage. Super quiet muffler with USFS approved spark arrestor eliminates errant sparks. Inverter system with Pulse Width Modulation PWM control can run products with built in microcomputers or microcomputer controlled electric tools. DC outlet 8A 12V outlet for charging batteries cables included . Rubber vibration isolation feet for increased smooth operation and noise reduction. Overhead valve engine with cast iron cylinder liner is efficient, reliable, powerful providing long life and excellent heat dissipation. Easily detachable side panels for easier service ability.
- TwinTech capability Hook up two EF2400iS's for 4600 watts of maximum power.
- Auto decompression system Reduces compression for easier starting.
- Gasoline petcock Helps prevent carburetor contamination during storage.
- Controls all on one panel Easy access to controls.
- Smart Throttle varies engine speed based on load Improves fuel economy and reduces noise.
- Comfortable grip handles Easy portability and storage.
- Fuel gauge Ability to gauge fuel level without opening cap.
- OilWatch warning system Prevents engine damage Provides added peace of mind.
- Electrical overload breaker Prevents generator damage in case of overload.
- Super quiet muffler with USFS approved Spark Arrestor Only 53 dBA at 1/4 load...eliminates errant sparks.
- Die cast aluminum frame Light weight, high strength.
- Inverter system with Pulse Width Modulation PWM control Can run products with built in microcomputers or microcomputer controlled electric tools.
- DC outlet 8A12V outlet for charging batteries cables included .
- Rubber vibration isolation feet Absorbing feet for increased smooth operation and noise reduction.
- Multipole alternator Light, compact design with great power output to weight ratio.
- OHV engine with cast iron cylinder liner Efficient, reliable, powerful providing long life and excellent heat dissipation.
- Easily detachable side panels For easier serviceability.
- Noise Block sound reduction system Very quiet.
View this ad at Forest River Classifieds -
SOLD: Pair of Yamaha EF2400iS inverter generators with Paral...
