[table]<colgroup><col /></colgroup>[tr]<th>
RoadTrip Mission Satllite Winegard. Condition is "Used". This was installed new on our Forest River Legacy Class A Motorhome and was on the Coach when we purchased it.
New, the Satellite sold for 1234.00 without the Directv HD converter boxes.
System is complete with the exception of the mounting brackets, which are 14.99 at Camping World. This could also be used for tail gating, easily set up on a remote tripod.
Shipping actual cost
Black Dome
Compatible with Directv SD, Dish SD amp; HD and Bell SD amp; HD. Supports 2 receivers.1 button for on/off.Automatic aiming antenna.
In motion model.Low profile with small print.Weather resistant.
Dimensions: 12.9" height, 20" diameter.
ROADTRIPMISSION IN MOTION SATELLITE ANTENNA BY WINEGARD
Hook up the Winegard RoadTrip Mission In Motion Satellite Antenna White to get the clearest picture on your TV while in motion on the road. Enjoy the luxury of watching television while on your next camping trip, the installation is a quick and easy mount and the automatic aiming will find a signal easily in minimal time.
TELEVISION FOR YOUR RVIN MOTION
If you don't want to miss your favorite TV shows, while on a road trip, this antenna will prevent you from missing them while traveling on the road to your destination and give a high quality picture to your RV television. Also keep the kids busy with cartoons on those long trips. You can also get HD programming for the clearest picture on the road.
AUTOMATICALLY FINDS A SIGNAL
Even if you are in motion, this antenna is made to automatically find a signal with the automatic aiming, you no longer have to do it manually or use a crank to get the programs your looking to watch. It receives Directv, Dish and Bell, giving you more channels than ever to choose from. The installation is simple, mounting to the roof of your RV.
TECHNICAL SPECS..
Type: roof mount.
View type: in motion.
HD compatible: yes.
With coaxial ports: 2.
Height: 12.9".Diameter: 20".</th>[/tr][/table]
View this ad at Forest River Classifieds -
Winegard RoadTrip Mission Satllite with Direct TV Converter...
