Old 09-14-2021, 12:55 PM   #1
Yamaha EF2400iSHC 2,400 watt Tri Fuel Inverter / Generator with cover Sacramento
I'm selling my Yamaha EF2400iSHC inverter generator with an add on Tri Fuel kit. The Tri Fuel kit allows you to run the generator on gasoline, propane or natural gas. The generator is in excellent condition and runs like new. Well maintained with frequent oil changes using synthetic oil. Comes with a Yamaha cover, 4 rubber caster wheels to easily move around, propane hose and users manual.
The inverter was purchased for emergency backup purposes and rarely got used. When it was used it was usually run on propane.
Manufacturer Description:
The 2400 Watt Yamaha EF2400iSHC weighs 75 pounds and has a dual handle design, making it easily portable. With an aluminum die cast frame, the EF2400iSHC features Smart Throttle which allows greater fuel efficiency and noise reduction. It will run up to 8.6 hours at rated load on a tank of gas. With features such as Pulse Width Modulation, at a glance fuel gauge, and an Oil Watch Warning System, the EF2400iSHC is a great choice for a medium sized portable inverter!
Features:
Yamaha generators have the longest emission engine durability ratings issued by the Environmental Protection Agency and the California Air Resources Board.
Gasoline petcock lets you shut off the gas to run the carb dry for storage and helps prevent stale gas problems.
Fuel gauge allows fuel level to be seen at a glance.
This model boasts High Current Output which is designed specifically to increase motor starting capability and to improve air conditioner starting. This High Current model starts most high efficiency 13,500 btu AC in temperatures up to 110 F.
The EF2400iSHC has an aluminum die cast frame, combined with an aluminum TCI rotor and other weight saving measures to provide a powerful and compact generator weighing only 75 pounds.
The EF2400iSHC uses Pulse Width Modulation PWM to produce high quality electricity comparable to the power supplied by public utilities. Use this generator with confidence as a power source for microcomputer controlled appliances and other devices with built in computer functions.
Yamaha s Smart Throttle feature automatically adjusts engine speed to match the load. The result is quiet running, maximum fuel efficiency, and a run time of 8.6 hours at 1/4 capacity load.
Yamaha s Oil Watch Warning System helps prevent engine damage from low oil and provides added peace of mind.
High Current output Increased motor starting capability and improved air conditioner starting. This High Current model starts most high efficiency 13,500 btu AC in temperatures up to 110 F.
Smart Throttle feature Adjusts the engine speed to precisely match the load.
Oil Watch Warning system Prevents engine damage caused by low oil, avoiding costly repairs and minimizing down time, adding customer confidence and peace of mind.
OHV engine Improved efficiency, increased reliability, quieter operation.
Versatile power in the silent, 2000 watt class Will run most 13,500 btu RV air conditioners, microwave/convection ovens, or even the biggest hair blow dryer.
Engine speed at full load 2400 watts is only 3400 rpm Quiet operation.
Cast iron cylinder liner Provides long engine life and consistent performance during continuous use.
Fuel gauge See fuel level at a glance.
Aluminum die cast frame Strong yet lightweight.
12 volt DC cable is included as standard equipment Charge RV, ATV, motorcycle, marine, and automotive batteries.
View this ad at Forest River Classifieds - Yamaha EF2400iSHC 2,400 watt Tri Fuel Inverter / Generator w...
SacRV is online now   Reply With Quote
