Old 08-07-2022, 07:01 AM   #1
KennyGolub's Avatar
Another "What is this?"
It's not a roof vent as it is completely sealed. There are several other roof vents. This one is located over the kitchen area of the 39RKFB. I'm stumped.
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is online now   Reply With Quote
Old 08-07-2022, 07:04 AM   #2
Attic vent
2020 Ram 3500 Dually
MichaelA is offline   Reply With Quote
Old 08-07-2022, 07:16 AM   #3
KennyGolub's Avatar
Originally Posted by MichaelA View Post
Attic vent
But there is no opening for air to get in/out ??
Ken & Laurie
Old 08-07-2022, 07:21 AM   #4
I’m trying to remember my roof…. IIRC there are two up there and (provided nobody sealed it up) the bottom goes into the top in such a way that water cant get in.
A pic of a cleaner one might make it more evident:
https://www.google.com/aclk?sa=l&ai=...4EQwg96BAgBEEw
Old 08-07-2022, 07:32 AM   #5
KennyGolub's Avatar
Thank you for that. Next time I go up there, I will look closer.
Ken & Laurie
Old 08-07-2022, 09:22 AM   #6
maybe something USE to be installed there and this was put there to close the hole?
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 08-07-2022, 10:47 AM   #7
Yea, that's what its supposed to look like. Someone used WAY too much sealant around it.
Iwritecode is online now   Reply With Quote
Old 08-07-2022, 11:22 AM   #8
KennyGolub's Avatar
I don't believe so.....I purchased it brand new this last March. I just happened to be on the roof to install my SoftStart's and noticed this.
Ken & Laurie
Old 08-07-2022, 10:18 PM   #9
Satellite?
Maybe it covers a connection for a satellite dish?
2016 Blue Ridge 3025
2012 GMC 2500HD 4x4 Dura Max crew cab
RonAnne48858 is offline   Reply With Quote
Old 08-08-2022, 12:57 AM   #10
You could contact the dealer and email the picture to them. Perhaps they forgot to install something.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 08-09-2022, 06:56 AM   #11
The Newsoms's Avatar
My Cardinal had this and the roof satellite wires were under it. It had a label on it though.
The Newsoms is offline   Reply With Quote
Old 08-22-2022, 10:20 PM   #12
Freebird2020's Avatar
Yes. It's an attic vent. I had one blow off. I found out it is pretty common so it's a good idea to check them after a trip.
2017 Cedar Creek Champagne 38EL
2020 Silverado 3500 SRW High Country
Freebird2020 is offline   Reply With Quote
Old 08-23-2022, 10:25 AM   #13
If there's no gap between the cover and sealant somebody screwed up when it was built. It' a vent for the roof between the outer roof and inner ceiling. It vents moisture & heat from that space. The plastic gets very brittle and they break easily. I have removed both my plastic vents and installed steel vents. The steel vents need some fine mesh added when you install them to keep the bugs/rodents out.
ken
2012 Sanibel 3500
11 GMC 3500 dually, Duramax/auto
kdanie is offline   Reply With Quote
Old 08-23-2022, 11:43 AM   #14
KennyGolub's Avatar
ken
I found the vent side facing the rear. When I first saw it, I viewed it from the front.
Thanks to all !!!
Ken & Laurie
Old 08-23-2022, 12:52 PM   #15
U.S.ArmyVeteran's Avatar
Looks like a Boonie hat to me :-)
U.S.ArmyVeteran is offline   Reply With Quote
