Old 08-07-2022, 07:01 AM   #1
KennyGolub's Avatar
Another "What is this?"
It's not a roof vent as it is completely sealed. There are several other roof vents. This one is located over the kitchen area of the 39RKFB. I'm stumped.
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 08-07-2022, 07:04 AM   #2
Attic vent
2020 Ram 3500 Dually
MichaelA is offline   Reply With Quote
Old 08-07-2022, 07:16 AM   #3
KennyGolub's Avatar
Originally Posted by MichaelA View Post
Attic vent
But there is no opening for air to get in/out ??
Ken & Laurie
Old 08-07-2022, 07:21 AM   #4
I’m trying to remember my roof…. IIRC there are two up there and (provided nobody sealed it up) the bottom goes into the top in such a way that water cant get in.
A pic of a cleaner one might make it more evident:
https://www.google.com/aclk?sa=l&ai=...4EQwg96BAgBEEw
Old 08-07-2022, 07:32 AM   #5
KennyGolub's Avatar
Thank you for that. Next time I go up there, I will look closer.
Ken & Laurie
Old 08-07-2022, 09:22 AM   #6
maybe something USE to be installed there and this was put there to close the hole?
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 08-07-2022, 10:47 AM   #7
Yea, that's what its supposed to look like. Someone used WAY too much sealant around it.
Iwritecode is online now   Reply With Quote
Old 08-07-2022, 11:22 AM   #8
KennyGolub's Avatar
I don't believe so.....I purchased it brand new this last March. I just happened to be on the roof to install my SoftStart's and noticed this.
Ken & Laurie
Old 08-07-2022, 10:18 PM   #9
Satellite?
Maybe it covers a connection for a satellite dish?
2016 Blue Ridge 3025
2012 GMC 2500HD 4x4 Dura Max crew cab
RonAnne48858 is offline   Reply With Quote
Old 08-08-2022, 12:57 AM   #10
You could contact the dealer and email the picture to them. Perhaps they forgot to install something.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-09-2022, 06:56 AM   #11
The Newsoms's Avatar
My Cardinal had this and the roof satellite wires were under it. It had a label on it though.
The Newsoms is offline   Reply With Quote
Old 08-22-2022, 10:20 PM   #12
Freebird2020's Avatar
Yes. It's an attic vent. I had one blow off. I found out it is pretty common so it's a good idea to check them after a trip.
2017 Cedar Creek Champagne 38EL
2020 Silverado 3500 SRW High Country
Freebird2020 is offline   Reply With Quote
Old 08-23-2022, 10:25 AM   #13
If there's no gap between the cover and sealant somebody screwed up when it was built. It' a vent for the roof between the outer roof and inner ceiling. It vents moisture & heat from that space. The plastic gets very brittle and they break easily. I have removed both my plastic vents and installed steel vents. The steel vents need some fine mesh added when you install them to keep the bugs/rodents out.
ken
2012 Sanibel 3500
11 GMC 3500 dually, Duramax/auto
kdanie is offline   Reply With Quote
Old 08-23-2022, 11:43 AM   #14
KennyGolub's Avatar
ken
I found the vent side facing the rear. When I first saw it, I viewed it from the front.
Thanks to all !!!
Ken & Laurie
Old 08-23-2022, 12:52 PM   #15
U.S.ArmyVeteran's Avatar
Looks like a Boonie hat to me :-)
U.S.ArmyVeteran is offline   Reply With Quote
