I have a Riverstone 391FSK, however the auto lights in all basements should be the same. The lights are supposed to on/off with doors open/close. The light on the door side of mine will not go off. I am hoping someone has traced down the auto on/off mechanism and can reply. Is this a mechanical switch or sensor and where is it located?
Solved the problem within 60 seconds of posting the thread, but I will post the findings in case anyone else has the issue. It is a sensor on the light housing and there is also a switch on the opposite side of the housing. My switch somehow got flipped to on. Now it is back to working as a sensor light, door closed, light off.
