Old 12-20-2019, 08:07 PM   #1
Best rated/Safest 5th wheel hitch
Hello to all and Merry Christmas. My wife and I have a Riverstone 39 RKFB on order and I am now researching, what is the best and safest tow hitch to pull our 39 RKFB. We are buying a new Dodge 3500 series dually with a diesel, 4X4, and this should be more than enough truck to pull this fifth wheel with no problems at all. The 39 RKFB fifth wheel is a pretty heavy model with the dry weight over 16,000 lbs and the max weight over 19,000 plus lbs. Although a heavy fifth wheel compared to some on the market, this truck should definitely tow this unit without any problems. We would appreciate any suggestions and input regarding our purchase of a fifth wheel hitch to be installed in the truck bed. There are many hitches available and our truck bed will have the pucks covering the factory pre-drilled holes for the hitch. The truck will have an 8 ft. bed for more stability and maximum turning radius. We would love your feedback and expertise in what you would might recommend as a quality and safe tow hitch. Thanking you all in advance and again Merry Christmas with always safe travels. God Bless !!!!!
RSLegacy is offline   Reply With Quote
Old 12-20-2019, 09:14 PM   #2
Merry Christmas to you too.
'Best' and 'Safest' threads quickly turn into opinionated debates. And what works for me may not be your cup of tea.
With that said, I've had about 4 different brands of 5th wheel hitches over the years and all of them have worked exactly as advertised.
Do you have any preferences?
What have you liked or disliked with what you have looked at?
Not sure what you mean by the pucks will cover the factory pre drilled holes? The pucks are the mounting points.
I hope you can receive the information you are looking for.
Let the debates begin...
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 12-21-2019, 05:43 AM   #3
Well, I just throw what I use without an issue for 5 years now; Reese 26K hitch. Bought with my truck and factory/dealer installed. 20,000 miles towed so far and no issues (knock on wood). Like 5picker so accurately said, just my opinion. Never had any other so I have nothing to compare it to.
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 12-21-2019, 06:57 AM   #4
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Exactly my thoughts. Merry Christmas to all!
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 - 2019: 955 ~ Nights Camping 2020: 5 (Slowed a bit due to wife's knee replacement and then COVID-19)
rjshiflet is offline   Reply With Quote
Old 12-21-2019, 09:18 AM   #5
Hard to beat the B&W Companion hitch, many RiverStone owners are using them for their rigs.
Fishrsafe is offline   Reply With Quote
Old 12-21-2019, 09:29 AM   #6
as stated many opinions. i'd look at how to get the hitch in and out of the truck. can it be broken into pieces that can be moved in and out of the bed? will you b e able to use a hoist to lift in in and out? i'd also think quite a bit about going up to a hitch with 24K or 25K weight capacity. a 20K hitch is close to the 19+K weight you say you will be towing.
in all the time i have been reading these forums i think i can only recall one post about a hitch actually failing. there are lots of 5th wheels out there being towed and the
hitches seem to be quite safe. again, consider going to higher hitch with as higher weight rating.
we also have a ram 3500 with the factory pucks. it's been a while since i checked on the specs for the factory puck mountings but just double check that they can handle the weight you will be towing.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 12-21-2019, 09:35 AM   #7
AirSafe hitch on Ford factory puck system. BedRug liner and BedLocker
cover.
I make no claims for it being the "best" or the "safest". But it is a quality setup from reputable companies. We're very happy with it.
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
Old 12-21-2019, 11:06 AM   #8
Jim34RL's Avatar
The one you can afford at a reasonably expense. You can purchase a new hitch for as little as $540 on Ebay to more than $2,000. Only you can decide on what you want to spend.
I spent around $1,100 for my second hitch a DEMCO Glide. My first was a 16K REESE manual slider that I had for 10 years. The hitch cost of the Reese was part of my first 5er that I purchased.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 12-21-2019, 11:19 AM   #9
frank4711's Avatar
My choice B&W ...simple no spring loaded handle ... Patriot 18K .. American made welded ... Strong and quiet 4 height levels ... ...
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 12-21-2019, 02:25 PM   #10
primo20's Avatar
To me, a hitch is not a place to skimp.
Ive had 2 B&W and in between them i had a curt. I hated the Curt and only used it on one trip to florida and went back to the B&W.
you'll probably get lots of endorsement for an anderson and a B&W.
for the 5th wheel prepped truck you should look at the B&W companion.
2018 DURANGO 2500 343MBQ | 2019 Silverado 3500 DRW Duramax
primo20 is offline   Reply With Quote
Old 12-21-2019, 02:26 PM   #11
Retired Member
RMWSierra's Avatar
I have the Mopar 30K hitch that came with my 3500 Ram. Have pulled 5th wheel 15k miles in a little over a year with no problems. Similar in operation to the B&W Companion I had in previous truck. I like both.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
RMWSierra is offline   Reply With Quote
Old 12-21-2019, 02:51 PM   #12
We have the same model camper as you. We bought a B&W Companion 25k hitch. Works awesome for us.
mikegernes is offline   Reply With Quote
Old 12-21-2019, 04:04 PM   #13
Currently using a Curt 24K on my RiverStone 38FB.
Been using it for 5 years and about 30K miles. It has worked well but can be a real pain to unhitch. Good value for the $$ but I will be switching to B+W
Companion.
What ever hitch you choose, I suggest a minimum of 24K.
2017 RiverStone Legacy 38FB
2018 Ram DRW, long box, Aisin, 4:10
Curt 24
Albertaslim is offline   Reply With Quote
Old 12-21-2019, 04:34 PM   #14
BandJCarm's Avatar
If I had it to do over, and if I had the money, a Trailer Saver BD5 Air Ride hitch.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-21-2019, 06:28 PM   #15
Jim1521's Avatar
Same here with my 39FK
2020 Riverstone 39FK
2016 Ford F-350 DRW 6.7L PowerStroke Lariat
Jim1521 is offline   Reply With Quote
Old 12-21-2019, 06:42 PM   #16
I don't use a travel trailer, but I have installed numerous hitches, fifth wheel, and under mount. B&W is well engineered, high strength steel and perfect welds on their products. I have been a welder/fabricator for over 50 years so I know quality when I see it.
Just always do a pull test before you raise the jacks all the way. All hitches.
aircommuter is offline   Reply With Quote
Old 12-21-2019, 08:04 PM   #17
I pulled a 20K 5ver with a RAM dually LB CC with 4.10. Very smooth and no problems. Good choice.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2018 RZR XP 1000 Ride Command
rskeans is online now   Reply With Quote
Old 12-21-2019, 08:53 PM   #18
New to FR. Old to TT
We have a CC36ck2, not as heavy as yours but you would still be within in the ratings for our Andersen hitch . It is very easy to hookup and doesn't need a break test after hook up, just lower on the ball push in the lock cable and all set. No clunking when over bumps or at starts and stops. Only needs the goose ball as attachment to truck, just make sure you check torque AFTER putting camper on the ball and raising the front jacks. We have pulled with this hitch for almost 2 years and over 14,000 miles. Good luck with your choice.
Tall frog is offline   Reply With Quote
Old 12-21-2019, 10:13 PM   #19
All Duallys are not created equal
I know you’re asking about hitches but I thought I’d pass on what I learned about Ram Duallys. If you were to buy one with 3.42 gears and the 68rfe transmission it may not have the towing capacity you need. Aisin transmission and 4.10 gears has a 30,000lb tow rating. The 3.42 was under 19,000 I think. I was shocked.
If I had bought the 8’ bed I would’ve bought B&W. American made and great quality.
2014 Cardinal 3850RL
2017 Ram 3500 drw megacab HO Aisin limited
Rbare31 is offline   Reply With Quote
Old 12-21-2019, 11:00 PM   #20
x2
Good point. I had the Aisin transmission. Highly recommended.
2019 Rubicon JLU
5th wheel, hitch, wheel
