Old 04-03-2018, 08:09 AM   #41
NMWildcat's Avatar
Originally Posted by dblr View Post
We have had our RS now for it's 3rd season and have been happy with the tank less system and have not had any issues with it, but starting this year the water seems to be only the hottest in the shower but it's cold out and the water coming in is colder. I hope when things warm up it settles back to what we are use to, am I missing something that needs adjusted or tweaked, I did raise the control setting on the panel in the bathroom.
Our on demand doesn't have any settings like yours, but when we have very cold input water we use just the hot water knob (as normal) and turn the flow rate down as low as possible without turning it so low that the on demand kicks off. Water stays in the heater longer. Works for us to get hot showers.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 04-04-2018, 09:21 PM   #42
GFAR's Avatar
Originally Posted by SomedayIsToday View Post
We had same problem until I read some other comments on another related post about water pressure. As soon as I increased the pressure to between 55-60 psi we had no more issue with that problem.
Good luck!
Larry
How did you increase water pressure? Stared mine up today at home would heat and then stop because of water flow, call tech at Girard he said not enough water flow to make heater fire and run! How can you adjust?
Thanks!
GARY
GFAR is offline   Reply With Quote
Old 04-04-2018, 09:58 PM   #43
SomedayIsToday's Avatar
Thanks!
GARY
I use an adjustable water pressure regulator like the Renator M11-0660R
Larry
-2017 RAM 3500 LARAMIE CC DRW LB 6.7L Cummins AISIN 4.10 4X4
-2017 RiverStone Legacy 38RE
U.S. Army Retired
Traveling Full-Time Since 5/4/2018
SomedayIsToday is offline   Reply With Quote
Old 04-05-2018, 08:19 AM   #44
GFAR's Avatar
Where did you get? About how much do they cost? I guess it go on waterhose before hooking to rv!
Old 04-05-2018, 06:16 PM   #45
I got mine from Amazon but they are available at just about any RV supply store. I think I spent about $40 on mine.
U.S. Army Retired
heater, tank, tankless, water, water heater
