Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 12-04-2021, 03:07 PM   #1
Gravity Water Fill ??
Does the 39 RKFB have a gravity water fill for disinfecting the fresh water tank ?
If not, is the only way to do it by putting your bleach in the fresh water fill hose ?
Ken & Laurie
2019 Entegra Aspire 44W
2020 RAM 1500 Laramie
KennyGolub is offline   Reply With Quote
Old 12-05-2021, 08:36 AM   #2
SeaDog's Avatar
A picture of your wet bay would help
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-05-2021, 08:50 AM   #3
I don't own one. It's one of the questions I have prior to purchasing. And of course, there are none on the dealers lots to look at.
Thanks !
Ken & Laurie
Old 12-05-2021, 11:45 AM   #4
Your wet bay will have a setting which will enable you to siphon directly to your fresh water tank.
I use this function to top up my fresh water while dry camping and also to add a bleach solution to sanitize.
2017 RiverStone Legacy 38FB
2018 Ram DRW, long box, Aisin, 4:10
B & W Companion
Albertaslim is offline   Reply With Quote
Old 12-06-2021, 06:24 AM   #5
So I use a short siphon hose to put in the water jug/container and connect the other end to the water inlet, set to that setting and it draws out the water/bleach mixture ?
Thanks !!
Ken & Laurie
Old 12-06-2021, 06:36 PM   #6
Here's the hot ticket for injecting chlorine bleach into water via your hose.
This particular hose end fertilizer sprayer has both hose in and hose out connections. Fill the jug with the appropriate amount of bleach, connect the hose to the input and a short hose between the output and your RV's hose connection, and you're good to go. Divert the city water connection to the fresh tank and turn on the water. Be sure to run the water pump to pickup and circulate the mixture through the pickup line and pump.
You can then refill the sprayer cup with about 1/2 cup of bleach, divert the city water from the fresh tank to the house and similarly sanitize your entire plumbing system.
The cup holds 32 oz. of bleach, so don't fill it full...at 1/4 cup bleach per 10 to 15 gallons, you may only need 2/3 to 1 cup (6 to 8 ounces) of bleach depending on your tank size. The hose end sprayer will pickup and disolve the bleach as the water goes through the sprayer.
I've used this method for years even with gravity feed. In fact, I install the fertilizer sprayer onto the hose bib (rather than the hose end), with a little extra bleach, and use the mixture to sanitize my potable water hoses connecting the household supply to the rig. Works great, and it's a no brainer.
I can't attest to the precise strength of the solution, but I know the cup is empty of bleach (no noticable smell) by the time I've filled my 30 gallon tank.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito
jimmoore13 is offline   Reply With Quote
Old 12-06-2021, 07:06 PM   #7
Just pour your bleach in the hose before connecting to the camper, then add bleach and water to the tank.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 12-07-2021, 10:52 AM   #8
Thanks !!
Yes
_______________
2020 Plat F350 diesel DRW
2021 Riverstone Legacy 37mre
filthy-Beast is offline   Reply With Quote
water
