Old 11-25-2020, 06:27 PM   #1
Plug It Right
Help with TV reset
We have a 2018 Riverstone Legacy 38RE. Both TV's have displayed fine until about 2 weeks ago.
Our living room TV, a 65" Samsung, started acting up about 2 weeks ago. On all recorded programs, we now have to manually adjust the screen to fit the TV every time. A Samsung rep said to unplug it to refresh it. Has anyone done this? I'm concerned that once I get my arm behind the TV I'm concerned that I won't be able to get the plug back in. Any help you can give me would be greatly appreciated. Hugs, Di
PS HAPPY THANKSGIVING
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.
Dutch & Di is offline   Reply With Quote
Old 11-25-2020, 06:38 PM   #2
Just turn the power of to that outlet?
mandl
mandl
mandl is offline   Reply With Quote
Old 11-25-2020, 06:42 PM   #3
Studog's Avatar
That's what I was going to say, but Samsung should be able to walk you threw more than a refresh if that doesn't work
Studog is offline   Reply With Quote
Old 11-25-2020, 10:33 PM   #4
zs325RES's Avatar
Samsung is right - do a hard boot and unplug or turn off the breaker while the TV is on. Wait a minute and then restore the power.
I’ve had to do this and it works.
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 11-26-2020, 12:48 PM   #5
Try starting up the TV with the remote by pressing and holding down the on button for 10 seconds or so.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 11-26-2020, 06:49 PM   #6
mandl
Right--just flip off the breakers at the power center. If you have a generator, don't let it start. Wait a few minutes. Turn the breakers back on.
If you don't want to flip off all the breakers, turn on the TV. Turn a breaker off. If that doesn't turn off the TV, turn it back on and try the next one. When you find the one that turns off the TV, label the breaker, wait a few minutes, and turn it back on.
Larry
Larry-NC is offline   Reply With Quote
Old 12-03-2020, 06:06 PM   #7
Jim1521's Avatar
You should also be able to do a software factory reset.
Go into MENU.
Go to SUPPORT
Go to SELF DIAGNOSIS
From here you can try a number of things. If all else fails...
Go to RESET
2020 Riverstone 39FK
2016 Ford F-350 DRW 6.7L PowerStroke Lariat
Jim1521 is offline   Reply With Quote
