I have a new 42FSKG and am trying to locate the turn on for the ice maker line. I did not see it on the manifold, so I suspect it is fed from another feeder maybe. Did not see it under the sink. I see the line above the front storage going back, but haven't traced it further yet. Anyone know?
We do not have that model but our valve is on the bottom of the rig about under where the fridge resides. Ours is a valve that you push/pull for open/closed.
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
I will take a closer look. I thought it might have been its own feed on the manifold, which would make the most sense to me, but I was not able to see anything labeled for that. I suppose I will just check for anything that is turned off next time I am at the trailer. I also checked the cabinets for an access door or something but was not able to find anything there, either.
It is located in the first main bay under the inverter. It is white. Push it in to make ice. Pull it out to shut off the ice.
