Old 10-22-2020, 12:02 AM   #1
Jim1521's Avatar
Mopeka Tank Check
I did some research on finding an accurate way of determining how much propane is available in each of my 40 lb tanks and came across Mopeka Tank Check. I bought it and installed it in my RV.
It works fantastic.
It has a magnetic ultrasonic sensor that sticks to the bottom of the tank And sends the data via Bluetooth to your iPad or Android device. It also has it’s own monitor panel that has an LED readout for each tank. I mounted by my master control panel.
The Android and iPad app work great and give you precise readouts of the status of the amount of propane that remains, the battery life of the sensor, and the signal strength from the device. Great, easy to use screens, and it set up in about 5 minutes.
Selecting one of the tanks zooms in for greater detail:
I got it from Amazon
2020 Riverstone 39FK
2016 Ford F-350 DRW 6.7L PowerStroke Lariat
Jim1521 is offline   Reply With Quote
Old 10-22-2020, 04:21 AM   #2
marinerjoe's Avatar
Iíve been using them for years. Great product.
Joe
Current: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
tank, check
