Old 08-08-2022, 11:27 PM   #1
Outside TV installation
I'm thinking about installing a TV in a pre-wired space on the outside of my 2021 Riverstone Reserve 3670RL. Any installation tips on this (I could not find a how-to-video), especially what mounting bracket I should use?
Bama76 is offline   Reply With Quote
Old 08-09-2022, 08:45 AM   #2
I don't think there are any instructions available.
We have an outside tv installed in a similar outside space on our unit. It's basically a flat mount that's thin enough to let the mount and tv fit in the space. So you're going to have to do some measuring for depth and find a tv and mount that will fit in there.
The problem is that it doesn't swivel. If I were ambitious, I'd attempt to find a swivel mount, but that's pretty low on my priority list.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 08-09-2022, 09:42 AM   #3
I would get a swivel - tilt mount made for an RV that will lock into place for travel. In ours the outside TV mount would be directly opposite the dining table supports into an area made to support it.
_______________
2020 Plat F350 diesel DRW
2021 Riverstone Legacy 37mre
filthy-Beast is offline   Reply With Quote
Old 08-10-2022, 07:15 AM   #4
The Newsoms's Avatar
We just ordered a swivel mount from Home Depot and a JBL television. We did use a piece of 1/4 plywood as a backer because the mount had a smaller mounting surface. We got a 40” because the 39” they say to use is hard to find. The 40” is tight but it does work. The hardest part is getting it centered in the hole.
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
The Newsoms is offline   Reply With Quote
Old 09-13-2022, 08:40 AM   #5
I purchased a Mounting Dream TV Mount (MD2413-MX) and a 43" Samsung TV. The installation was easier than I anticipated and everything works great! With the swivel mount, I was able to move the 43" TV both inside and outside of my 2021 Riverstone Reserve 3670RL outside TV storage area.
