Originally Posted by jd50i
You don't need to seal every "normal" leak in your RV, just pressurize it enough to show bubbles. You can use a small lawn sprayer to spray the soapy water. It doesn't matter if you have air coming out the stove vent or other places that aren't sealed you are looking for a leak where it should not be.
Ok, I know that you will have leaks that will not hurt! Thanks for info! I haven’t tried this yet
