Originally Posted by NMWildcat
No.
What is it you are trying to do exactly?
Auto level puts the bottom of the RV way too close to the ground in front. I manually raised the front, but that causes the rear jacks to extend further than I would like to keep everything level. I have jack stands I use on our concrete pad in Florida, and I would like to put them under the rear jacks so they don't extend so far.
If I raise the rear jacks, the middle ones go up also, and then the rear is too low to put the jacks stands under the jacks.
I guess it can't be done, so I'll have to live with the extended rear jacks until the next move.
Thanks for the reply.
