Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-06-2021, 01:58 PM   #1
The Newsoms's Avatar
Remove BR television
2018 38RE. I need to take the bedroom tv off to figure out some coax the previous owner messed with. Does anyone know how to get it down? It’s completely surrounded. There are some screws to the side but I’m not sure they will remove the side panel. Click image for larger version
ID:	265363Click image for larger version
Jimmy & Teresa Newsom
2018 Riverstone 38RE/2019 Sundowner Toyhauler
2020 RAM 3500 SRW
The Newsoms is online now   Reply With Quote
Old 11-06-2021, 02:18 PM   #2
lmiken's Avatar
is it screwed down or is it on a swing mount (does it wiggle if you out your hands on the sides of the TV)? Try to grab the edges to pull steardily and see if it will pop out of the locks (swing mount have a pressed in lock to hold them steady). Do jerk too hard just in case it is not swing mount)
2015 Flagstaff 32IKBS
2008 F350 6.4
1999 Palomino Filly Popup (my daughter's now)
lmiken is offline   Reply With Quote
Old 11-06-2021, 02:51 PM   #3
Not a swing mount. I feel it has to pull loose from the bottom but I’m scared to pull hard. I tried to look behind it with an endoscope but couldn’t tell anything.
2020 RAM 3500 SRW
Old 11-06-2021, 03:58 PM   #4
Briorick's Avatar
Is there possibly a Button Strap connected to the bottom? You say it has some resistance at the bottom, this is why I'm asking. Other than that, it must have some sort of locking traveling mechanism. The old owners surely ( at least one would think ) wouldn't have anchored it to wall without ever needing to remove it. Just my thoughts.
Rick & Brian
1 Happy Camper Pup ( Mya )
2019 Flagstaff HW29SC
2017 Salem Cruise Lite 232RBXL ( previous )
2011 Ford Super Duty 250 XLT FX4 6.2
Briorick is offline   Reply With Quote
Old 11-07-2021, 05:43 AM   #5
Don't have your model so it may not apply, but in my 38MB (living room) there is a button up about 8" from center that you have to press, then lift off the tv. Two person job on the living room tv as it's large. Again, may not apply to you. Good luck and keep us posted on how you did it.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 11-07-2021, 05:56 PM   #6
if it's like the bedroom TV in our 2021 37MRE the TV is bolted to the backing board. You have to remove the board by removing the 4 screws in the board then the TV and board come out together.
_______________
2020 Plat F350 diesel DRW
2021 Riverstone Legacy 37mre
filthy-Beast is offline   Reply With Quote
Old 11-08-2021, 09:43 AM   #7
Jim34RL's Avatar
Did you buy your RV from a dealer? If so, ask the service department on how to remove the TV. I asked my dealer's service department on how to remove my TV in the bedroom on a 34RL Cedar Creek.
They informed me to lift up to separate the TV from the bracket that was holding in my TV.
It doesn't hurt to ask the service department they usually will help you.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
Old 11-08-2021, 04:26 PM   #8
This was it. Thanks for the help.
2020 RAM 3500 SRW
Old 11-29-2021, 12:42 AM   #9
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
X2
All you need is a #2 Robertson and it only takes a minute or two to take it off.
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
Cypressloser is offline   Reply With Quote
Old 11-29-2021, 08:07 PM   #10
Thanks for the help. I got it off, sorted my coax, added an hdmi cable so that I could have one for the satellite receiver and one for the DVD player. I drilled a hole on the left side of the frame board and have it fixed so I can set my satellite receiver up on the window valance. Trying to make it look neat without cords and coax everywhere. I’m happy with it.
2020 RAM 3500 SRW
television
