We have the same oven and this is what I copied from the installation/manual pdf on the Furrion website:
From a 12V DC power source run a minimum 16AWG 2-conductor cable
or above to the upper
right rear corner of the
oven cavity, use a 5A fuse
at the power source for
protection.
It doesn't say there is an inline fuse, it may just be a 12 Volt fuse in the main panel. If the led display lights up and you hear the fan running you may have a bad igniter, try to ignite the pilot light with a bbq lighter .......
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
