Old 10-21-2019, 11:53 AM   #1
Slide wall thickness?
Looking to hang something on the wall of the kitchen slide. Anybody know how thick (thin) the slide walls are?
2020 Riverstone 39FK
2016 Ford F-350 DRW 6.7L PowerStroke Lariat
Jim1521 is online now   Reply With Quote
Old 10-21-2019, 12:19 PM   #2
Head Rambler
You should be able to look at the window and tell about how thick the slide all is. Generally they're 1" thick.
Gotta go campin!
Old 10-21-2019, 12:48 PM   #3
Thanks!
Old 10-21-2019, 01:49 PM   #4
Pretty sure Riverstone's are at least 3" if I remember when we bought ours. Just looked at my door frame. 3 maybe 3.5 even.
Rusty
2019 Riverstone Legacy 38MB
Full Paint Merlot/All Options
2015 Black Ford Platinum Diesel F-350 Dually
lcv800 is offline   Reply With Quote
Old 10-21-2019, 01:51 PM   #5
My bad. You were looking for slide wall. At least 1.5 and probably more.
Rusty
Old 10-21-2019, 02:00 PM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
3 1/4", same thickness as the main walls.
Cypressloser is offline   Reply With Quote
Old 10-21-2019, 03:17 PM   #7
I just pulled one of the kitchen slides part way in, felt on both sides of it, and best I can tell it is less than 2" thick on the sides. I'm going to use 3/4" screws, and will probably glue and screw a thin wood strip to the wall, then mount my magnetic knife rack to it. Between the screws and the glue it should hold adequately.
Old 10-21-2019, 03:34 PM   #8
I highly doubt that!
2018 Flagstaff Super Lite 29RKWS
2015 F 150 max tow
Where ever you go there you are
grumpyer is offline   Reply With Quote
Old 10-21-2019, 04:19 PM   #9
I just remeasured the slides, at least on our 2017 the slide walls are exactly 3" thick all the way around, the same as the main walls, advertised wall thickness is 3 1/4". Regardless, it won't hurt to measure the outside, subtract the flanges and the inside width to get to the wall thickness. RS may have made changed the wall thickness between model years, I hope not but who knows.
I used double sided tape and the supplied 3/4" wood screws to mount this knife holder, it's been up for 1 1/2 - 2 years.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Old 10-21-2019, 05:00 PM   #10
I used double sided tape and the supplied 3/4" would screws to mount this knife holder, it's been up for 1 1/2 - 2 years.
That's what I'm looking to do. I didn't think the double-sided tape would hold, but obviously it does. Thanks.
Old 10-22-2019, 06:01 AM   #11
Just heard back from Riverstone this morning. Slide walls are 2 3/4" thick.
Old 10-30-2019, 05:33 PM   #12
3M Command strips work great...many weight ratings. Also removable with no holes/marks on the wall.
"To invent, you need a good imagination and a pile of junk."
--Thomas Edison
Vernonfarmer is offline   Reply With Quote
Old 12-23-2019, 09:30 PM   #13
The Riverstone Walls are 3.25 thick
The aluminum walls are 2.5 inches thick, however when you factor in the insulation and coverings you end up with a wall that is 3.25 thick for the Riverstone models, which is one of the MFGs selling points for full time RVIng.
If you could locate one of the aluminum studs, then anchoring into one of them would give you a lot more strength than just attaching something to the wall boards between the studs.
MLJLC4473 is offline   Reply With Quote
Old 12-24-2019, 12:02 AM   #14
I have been using these with great success:
They are the perfect thickness (1/8") for the lauan wallboard.
Hillman 1/8" Pop-Toggles
slide
