Old 03-06-2020, 12:08 AM   #41
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Originally Posted by smittyboy View Post
Look at the goose box Pin Box if it will fit on to your trailer. You have the puck system, so all you need is the ball and safety chain hook up. The Pin Box has air bag and 2 shocks. We pull a Cedar Creek 29RE. With this Pin Box we get no chucking and rides smooth. When you remove the parts in the bed it is flat and the parts weigh maybe 50 lbs. You can hook to the trailer at any angle if needed.
The goose box, unfortunately, only has a 16k/3k rating and is not an option for even the smallest RS.
https://www.reeseprod.com/mobile/products/pin-boxes/goose-box/goose-box/Jsbr87GrqXnapVUQgaaYys7QyY0TL2Pv
Cypressloser is offline   Reply With Quote
Old 03-06-2020, 01:05 PM   #42
They have two Goose Box Pin Boxes. A 16k and a 20k. https://www.reeseprod.com/products/p...notJoVbxIFMqvl
smittyboy is offline   Reply With Quote
Old 03-06-2020, 04:28 PM   #43
My B&W Companion arrived; my rig should be here in 2 weeks if the world doesn't fall apart between now and then.
I am going to try that first and see how it does. If I have a problem with chucking and a rough ride I will look into the goose box and the BD5. Thanks for all the solid input.
jjackkrash is offline   Reply With Quote
Old 03-07-2020, 01:41 PM   #44
I have had a B&W hitch for 6 years with a TrailAir pin box for 5 years and it has always been a great combination until now. My new Silverado 3500 is a little tall. I was told this week by a rv service department that my TrailAir could not be raised up to lower the pin box. Iím going to Goshen IN for a few days next month and Iíll know some more then. Iím having a little trouble now with the puck system, I donít have the top nuts tight enough but Iíll fix that
travlinon is offline   Reply With Quote
Old 03-16-2020, 08:06 PM   #45
Well, the hot-shotter hooked up today and is heading down the road. If all goes well I should have my rig Thursday. Yah!
Old 03-21-2020, 10:59 PM   #46
It here! (Only took about 4 hours to wash the road grime off the exterior. .)
Old 04-05-2020, 01:58 PM   #47
We decided to go with the Gen-y gooseneck, it's similar to the reese.
https://genyhitch.com/product/execut...-torsion-flex/
SSGT USMC : 84-99
Current: 2020 4x4 Limited 3500 DRW Crew Cab 6.7HO Asin
Current: 2020 Riverstone Legacy 39RKFB
Grunt4Life is offline   Reply With Quote
