04-09-2021, 06:48 PM
19.6 Electrical draw issue?
I live in my 19.6 on 30amp 120vac power. I've found I can't use my microwave/convection oven, and coffee pot and instant pot at the same time so I only run 2 of the three at a time. I recently discovered I can't run my air conditioning and microwave/convection oven at the same time which is a bit upsetting since I live in Florida. Any experiences or thoughts about this issue and how to mitigate it, or am I stuck not baking at all after March?
04-09-2021, 07:17 PM
30amp at 120V is only 3600 watts. Microwave and A/C are both very high draw items. Depending on the size of the A/C, I can see it not running together.
04-09-2021, 07:21 PM
Run a separate circuit to the AC or to the Microwave that will plug into the 15 amp plug on the campground pedestal with an extension cord.
Retired Navy
2016 Flagstaff 26 FKWS
04-09-2021, 08:11 PM
You need to look at what power draws each item is making. It ain't like your house.
Everything you've listed, are high power items. You are trying to run too many things at the same time.
You would have needed a 50amp rig.
04-09-2021, 08:17 PM
X2
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
04-10-2021, 05:03 AM
I appreciate the responses, I understand the draw issue; being that the system is limited like that I'm a bit upset that it would be designed that way.
04-10-2021, 05:18 AM
All 30amp RVs are that way. If you want to run all those things at the same time, you should have considered a bigger 50 amp RV. They don't make 50amp 24ft trailers.
04-10-2021, 12:07 PM
Just flip off the A/C
Just flip off the air conditioner before you run the microwave. Maybe use the gas range instead.
Larry
04-10-2021, 12:20 PM
That is strange I have 30 amp 21ft and I run my air conditioner and microwave at the same time and have never had a problem try checking your breakers my be weak.
04-10-2021, 12:32 PM
There are to many variables to compare rigs as one should run mine does. AC units can vary greatly in amp draw especially at startup and their camp voltage may be on the low side causing more amp draw. With that said your idea to check the breaker is solid advice.
Retired Navy
04-10-2021, 12:46 PM
I also have a 30 amp system but have no problems running my microwave (1.35 Kw) and my A/C at the same time (1.5kw).
What does cause me grief is when I try to run them and both refrigerator and water heater are running their heating elements. Water heater on electric is a huge draw, often 1.5 Kw alone and the refrigerator heating element is usually around 300 watts.
When I need to run the A/C I just switch my refrigerator to gas as well as the water heater.
If I have shore power will run my Instant Pot and toaster on a separate extension from the power post.
Life in a Travel Trailer is all about resource management. Water, Holding Tanks, space, and electrical power usage.
Like said earlier, for more Home-Like power use, a 50 amp system is required.
BTW, don't forget battery charging. That can consume another 700 watts and often nobody ever gives that a thought.
04-10-2021, 12:59 PM
Try running one item on a separate extension cord (12 guage) directly to the 20 amp circuit on the pedestal. I used to do that with my electric water heater. Worked great.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
04-10-2021, 01:47 PM
there is an outside one, but an inside switch to shut off the water heater for a short time when needed has proven to be convenient and helpful for us, ... also, I bring a #12 extension cord into our trailer thru a hatch cover on a outside storage compartment door, once inside it can be used in any number of ways to relieve the 30a system of some of the amps used, ... I modified our air conditioner wiring and using a toggle switch, I run the ac with that extension cord, removing those 13a-15a from the 30a system, ... if we're at cg where they only have a 30a outlet on the power pole, I flip the toggle switch and the ac is right back on the 30a system, just like it came out of the factory, ... this has worked great for us, ...
04-10-2021, 01:51 PM
When we had our 30 amp; this is what we did too.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-10-2021, 02:02 PM
Kanadian Kamper
The house we grew up in only had 60 amp service until Mom sold it in her retirement years. I can’t count how many Mom blew fuses when trying the clothes dryer, with the A/C unit, or hair dryer, or coffee maker etc....
Turning off the A/C for the few minutes that you use a microwave in a 30amp rig, is not the end of the world. You get used to it. We have....downsizing from the 50amp Georgetown to our 30amp Sunseeker.
Ken and Terry
04-10-2021, 02:10 PM
I rented a house like that back when I was going to college. Half the fuses in the fuse box had pennies behind them.
04-10-2021, 02:11 PM
30amp RVs aren't 'designed' that way, as you lament, they are subject to the LAWS of electricity - would you rather they just NOT give you an air conditioner, since it can't work at full blast at the same time you want to microwave something? Or would you rather NOT have a microwave since it can't work at the same TIME the air conditioner is working??
RVing is all about compromises, after all, it's a very tiny house on wheels, and is certainly NOT going to be like your 3,000 sq ft home with 200amp service that never moves.
30amp RV power is the 'standard' for most campgrounds and rv parks for many, many decades. The RV industry just simply has to build 'around' that limitation. Or, you invest more money in the higher-end 50amp 240v RV with over THREE times the amount of 120v power. But, then again, finding a 50amp power source is not always a given, either, and then you are right back to the same issue you have now.
Managing electrical usage when in an RV is normal, there is no 'unlimited' electrical source that you can tap into - even homes sometimes trip breakers.
The Turners...
04-10-2021, 02:37 PM
When running air and need the micro-wave , switch air to just fan for the several minutes and then switch back to air . Been doing that for 30 years .
04-10-2021, 02:50 PM
So, those standard plug outlets at RV park pedestals are usually 20 amps or are they usually 15 amps)
04-10-2021, 03:29 PM
I see them with 20 amp breakers but rarely have I seen anyone plug in with a true 20 amp plug. Just regular household 15 amp plugs.
A 20 amp plug has one vertical blade and one horizontal.
20 amp receptacle on left, 15 on right. You can still plug in a 15 amp in a 20 amp but the one horizontal blade on the 20 amp plug will keep it out of the 15 amp.
If drawing the full 20 amp current through a 15 amp plug eventually the plug will have heat issues (like melting).
