Originally Posted by jspickett
Hi, I recently picked up a 2021 10.6 and have a problem with the kitchen slide. It has the Truma cooler and if I have it in the spot it's supposed to sit, I can't open the top of the cooler. In addition to this, The slide won't completely close because the cooler is hitting the wood in the back. I have to pull it all the way pressed against the stove to get the cooler to open. Has anyone had a similar problem?
I am pretty sure I know what is going on, the slide itself has some holes in it, the rubber foot on the Truma cooler may be stuck in it not allowing you to slide it closer to the stove. You need to pick it up and slide it closer.
Another possibility is the cloth strap may be blocking it from moving closer to the stove as well. Be sure the metal clip is not bound in a funny way not letting you slide it closer to the stove.
I have the Truma in my 10.6 and know how close the tolerance is first hand. As a matter of fact, we even upgraded ours to the higher capacity one which is even taller too.
Hopefully one of these suggestions helps. It is hilarious how many little things I needed to adjust after the dealer "prepped" it for us. Even the axle zirk fittings were dry but perhaps they justify it by hoping Forrest River did it during assembly.
