Originally Posted by bnimtz
Has anyone figured out a good rule of thumb or found a good guide on trying to estimate what the power consumption is of the NoBo electric items?
Have the solar package (1 panel on top), two regular deep cycle batteries, 12V Fridge, microwave oven, A/C.
2022 NoBo 19.8. Mainly looking for what generator size needed to reliability run 12V fridge and either A/C or furnace (propane). Along with misc lights and maybe a fan, radio, phone charger. Furnace controls and water tank heaters would come into play in the fall. I guess I’m not sure if the water tank heaters are electric or propane. Looking at an inverter generator like the Hondas or Generacs.
Thank you
First, you need to regroup.
The purpose of solar is to recharge batteries. It doesn’t power much on its own.
Many TT systems use 12vdc as control power even though they use propane as a heat source, furnace, propane fridge (not applicable for you), water heater.
Water heaters can be tricky. My Suburban water heater has an AC electric element but the power switch for electric is hidden under piping on the exterior.
Air conditioning uses a massive amount of power, even on small TT, pushing 15 amps. So if you want Air Conditioning, you’ll need either a massive battery bank and inverter, or a 3000 watt or so generator or the Honda 2200 watt inverter generator WITH a Soft Start module (~$240) installed in your Air Conditioner.
Best way I found to determine power use for AC current was to use a plug in Kill-A-Watt meter (available at Harbor Freight) and turn items on and off. I did have to use some adapters to be able to plug it in line on the TT power inlet jack. Readings in volts, watts & amps.
MY air conditioner, while running, uses 12.05 amps. I couldn’t see the startup reading since I started it inside and had to go outside to read the meter. I have since added the soft start but haven’t remeasured. I need to do that. I’m hoping my 2000 watt Honda will support the AC. Regardless, it will be tight power management, a pick one kind of thing, microwave (10.25 amps), water heater (10.38 amps), portable electric heater (12.5 amps), AC (12.05 amps), single serve coffee maker (6.67 amps). Basically anything with a motor or heating element.
I strongly believe that your current solar power system was designed to mostly support having an operating 12vdc fridge.
IIRC, wattage divided by voltage equals amperage. And conversely, amps times volts equals watts. Read the item label plate for power usage and do the math to figure power usage in the terms you need since most generators are wattage rated. Forget peak ratings except for motor startups. So my Air Conditioner uses 1446 watts at 120VAC while running.
