Old 05-08-2021, 04:41 PM   #1
NOBO no water
Stupid new guy here. I have a new 19.7. When I hook up city water it just overflows the tank and spurts out everywhere. Is there any way to make sure the division between the on trailer water system and the city water system don't comingle?
someguy is offline   Reply With Quote
Old 05-08-2021, 05:33 PM   #2
HONDAMAN174's Avatar
Cycle your water pump. The check valve is stuck open.
Just glad to get away
Old 05-08-2021, 05:58 PM   #3
Hi Hondaman,
Tried that a number of times. No luck.
Old 05-08-2021, 07:16 PM   #4
Just as confused as you
Scrapper's Avatar
There's a little more to it than just cycling the water pump.
1) Turn off the city water and open a faucet to release the pressure.
2) Turn on the wp and let the water run for a bit then turn off the faucet and let the wp run until the pump automatically shuts off.
3) Open the faucet and let the water run until the wp starts up then turn the faucet off.
4) When the wp starts again turn off the faucet and allow the wp to automatically turn off.
5) You may need to repeat #3 and #4 a couple of times.
6) Turn off the wp switch and turn on the city water.
Turning on or using the water pump while using the city water can cause the check valve in the wp to stick open. If the above procedure fails to solve your problem you can go to a hardware stores plumbing section and buy an external check valve and install it on the output side of the water pump.
Richard & Jill
Camping since 1989
Everyone gets confused at some time, some are better at hiding it than others.
Old 05-08-2021, 07:24 PM   #5
Originally Posted by Scrapper View Post
If the above procedure fails to solve your problem you can go to a hardware plumbing section and buy an external check valve and install it on the output side of the water pump.
If you add an external check valve it should go on the inlet side of the water pump, not the outlet side. If the internal check valve in the water pump is leaking by, and you put the check valve on the outlet side of the water pump, pressure in the pump will just bleed off through the leaking internal check valve back into the fresh water tank and the pump will cycle on and off even though no water is being used.
If you put the external check valve on the inlet side of the water pump, the internal check valve will still leak by but it will only leak by back to the external check valve on the inlet, not back into the fresh water tank. This will prevent the water pump from cycling on and off when no water is being used.
NavyLCDR is offline   Reply With Quote
Old 05-08-2021, 08:40 PM   #6
Scrapper's Avatar
The pumps built-in pressure switch exists after the internal check valve so your correct in the assumption that it is the main function. But the second purpose of the internal check valve is to prevent city water from back flowing into the fresh water tank such as OP is experiencing. Some have added the external check valve to the pumps output without experiencing what you describe.
Richard & Jill
Camping since 1989
Old 05-09-2021, 04:53 AM   #7
Thanks, I will give that procedure a try.
Old 05-10-2021, 07:48 AM   #8
Thanks again, that worked great
water
