Nobody 19.8 - Solar question
Hey guys - coming out from the shadows of lurking with a question about solar.
I have a 21 Nobo 19.8 that came equipped with Solar (190w panel - 10 amp solar controller). I'm adding another 190 watt panel and swapping the controller to the 30amp controller.
I'm to assume that the fuse breaker between the controller and battery is only rated for 10amps? Does anybody know where they would factory install that breaker so that I could check? The holes behind the controller and panels are tiny so I can't peek to see if its indeed in the wall.
TIA!
